Flyingmau5
Any examples of where a high density altitude is a benefit to us as pilots?
I can think of VMC being decreased. Anything else?
It's been a long day. I don't understand what that means.Any examples of where a high density altitude is a benefit to us as pilots?
I can think of VMC being decreased. ?
Assuming the decrease in power and airfoil efficiency doesn't keep you from reaching that IAS.TAS increase of 1% per each 600ft!
Only after a certain point. In the DA-40, for instance, at 65% power, you get a TAS of 130 kts at 6000 ft density altitude, approx 132 KTAS at 9000 ft density altitude, and then only 130 ktas again at 10000 ft density altitude. At the same power setting, you only get about 122 KTAS at 2000 ft density altitudeAssuming the decrease in power and airfoil efficiency doesn't keep you from reaching that IAS.
True enough.Only after a certain point. In the DA-40, for instance, at 65% power, you get a TAS of 130 kts at 6000 ft density altitude, approx 132 KTAS at 9000 ft density altitude, and then only 130 ktas again at 10000 ft density altitude. At the same power setting, you only get about 122 KTAS at 2000 ft density altitude
Rather eye-opening demonstrations of just what "balanced field length" really means.When you want to show a pilot what it is like to operate with minimal performance. Nothing like operating. Cessna 140 in the high desert during the summer for this. You can not perform a steep 360 turn while maintaining altitude.
