Nark
Macho Superpilot
So there I was deep in thought.
I can remember a guy telling me gas is cheap and brake pads are expensive.
However after aircraft ownership, and a few annuals later, brake pads aren't expensive. I got to thinking. For the amount of short field landings that I do on my bird, I use a lot of brakes, however I've only replaced the pads once.
Translating this to the transport jets and turbo props I've flown, how much gas am I burning from touchdown, using max reverse until 70 knots?
Multiply that across hundreds if not thousands of landings when brakes need to be replaced.
It is really cheaper over all?
@Roger Roger how often did you replace brake pads when we flew together?
